is it possible to create two scripts?
Josiah Inubio
Level 4
Level 4
Is it possible this way if I'm making two script? Thanks.
Script 1
For this log:
Apr 24 07:40:01.884 MNL: %LINK-3-UPDOWN: Interface Cellular0/2/0, changed state
to down
ROUTER(config)#event manager applet cell1
ROUTER(config-applet)# event syslog pattern "Interface Cellular0/2/0, changed state to down"
ROUTER(config-applet)# action 1.0 cli command "enable"
ROUTER(config-applet)# action 1.1 cli cmmand "configure term"
ROUTER(config-applet)# action 1.2 cli command "interface Cellular0/2/0"
ROUTER(config-applet)# action 1.3 cli command "no shut"
Script 2
For this log:
Apr 25 11:17:49.881 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/2 is DOWN
ROUTER(config)#event manager applet cell2
ROUTER(config-applet)# event syslog pattern "Modem in HWIC slot 0/2 is DOWN"
ROUTER(config-applet)# action 1.1 cli cmmand "reload at 19:00"
5 Accepted Solutions
Joe Clarke
These will work.  You can have them both configured at once.  However, the reload at is strange.  Is that the only way to recover?  Are you okay with waiting for a specific time to reload?
You could use a regexp to do this:
action 001 cli command "enable"
action 002 cli command "show clock"
action 003 regexp "([0-9]+):[0-9]:[0-9]" $_cli_result match hour
action 004 if $hour ge 17
action 005  reload
action 006 end
The regexp line extracts the hour portion of the time and the if lines compare that value to 17 (5pm) and 6 (6 am) respectively.  If the hour is greater than or equal to 17 or less than or equal to 6 (numerically) then the reload action will be invoked.
event manager applet mode-down
action 1.0 mail from [email protected] to [email protected] server 10.1.1.1 subject "Modem down" body "$_syslog_msg"
No.  Not given these scenarios.
event manager applet cell3
description "TEST ONLY"
event syslog pattern "Modem in HWIC slot 0/0 is DOWN"
action 0.5 set timed_reload 0
action 1.1 cli command "show clock"
action 1.2 regexp "([0-9]+):[0-9]+:[0-9]+" "$_cli_result" match hour
action 1.3 if $hour ge 18
action 1.4  reload
action 1.9 else
action 2.0  set timed_reload 1
action 2.1 end
action 2.2 if $hour lt 6
action 2.4  reload
action 2.8 else
action 2.9  set timed_reload 1
action 3.0 end
action 3.1 if $timed_reload eq 1
action 3.2  cli command "config t"
action 3.3  cli command "event manager applet reload-at-seven"
action 3.4  cli command "event timer cron cron-entry $q 0 19 * * *$q"
action 3.5  cli command "action 1.0 reload"
action 3.6  cli command "end"
action 3.7 end
62 Replies 62
Joe Clarke
It's the most convenient time to reload since our client business hours end at 17:00 or 5PM. So i don't want to put the connection down.
Is there as script that could identify when the time comes when the interface or HWIC modem will be down at 19:00 to 0600 and then reload it right away? So i don't have to wait 17:00.
action 005  reload
action 006 end
Wow, i'll try it and i'll let you know. Thanks so much on this. But is this right below?
ROUTER(config-applet)# action 1.1 cli command "show clock"
ROUTER(config-applet)# action 1.2 regexp "([0-9]+):[0-9]:[0-9]" $_cli_result match hour
ROUTER(config-applet)# action 1.3 if $hour ge 17
ROUTER(config-applet)# action 1.4 reload
ROUTER(config-applet)# action 1.5 end
Yes, but perhaps you want to do:
action 1.6 if $hour le 6
action 1.7  reload
action 1.8 end
And this will only work if the message comes in at that time.  It won't handle the case where the message comes in during business hours.  You would still want to add your reload at line in that case.
Sorry that i'm being persistent. I'm new at this.
Question, can you help me understand these scripts? the bold phrases.
ROUTER(config-applet)# action 1.6 if $hour le 6
ROUTER(config-applet)# action 1.7  reload
ROUTER(config-applet)# action 1.8 end
Appreciate it a lot!
Thank you so much for the assistance. Appreciate it!
hi joseph, i think the script is not working. i can't see any activity working based on the debug logs. thanks
Without seeing what you're seeing, I don't know what to tell you.  I'm honestly not even sure what the script looks like at this point.
here's what the script looks like
event manager session cli username "jvi01131990"
event syslog pattern "Interface Cellular0/0/0, changed state to down"
action 1.1 cli command "test cellular 0/0/0 modem-power-cycle"
action 1.3 if $hour ge 19
action 1.4  reload
action 1.5 end
action 1.7  reload
When one of these syslog messages is generated, what do you see in your debug output?  What does "show event manager history event" show?
to run cell1 manually, its successful, but not with cell2
PHILAM-COT-BR01#sh event manager history events
No.  Job Id Proc Status   Time of Event            Event Type         Name
1    1      Actv success  Mon Oct 7 13:12:01 2013  none               applet: cell1
CELL1
Oct  7 13:11:49.177 MNL: %SYS-5-CONFIG_I: Configured from console by jvi01131990 on vty0 (10.49.135.135)
Oct  7 13:12:01.293 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : CTL : cli_open called.
Oct  7 13:12:01.297 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : Reload scheduled for 20:00:00 MNL Mon Oct 7 2013 (in 6 hours and 47 minutes) by jvi01131
Oct  7 13:12:01.297 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : Reload reason: Reload Command
Oct  7 13:12:01.297 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : PHILAM-COT-BR01>
Oct  7 13:12:01.301 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : IN  : PHILAM-COT-BR01>enable
Oct  7 13:12:01.613 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : PHILAM-COT-BR01#
Oct  7 13:12:01.613 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : IN  : PHILAM-COT-BR01#test cellular 0/0/0 modem-power-cycle
Oct  7 13:12:10.925 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : Cellular
Modem in HWIC slot 0/0 is still in reset, we recommend to re-execute this cmd after 60 seconds
Oct  7 13:12:10.925 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : OUT : PHILAM-COT-BR01#
Oct  7 13:12:10.925 MNL: %HA_EM-6-LOG: cell1 : DEBUG(cli_lib) : : CTL : cli_close called.
CELL2
Oct  7 13:16:53.137 MNL: %HA_EM-6-FMPD_EEM_CONFIG: cell2: Missing "end" action in conditional block
Oct  7 13:16:53.137 MNL: %SYS-5-CONFIG_I: Configured from console by jvi01131990
Cell1 appears to be working.  In cell2, add:
action 1.8 end
That will take care of the error you see there.
