Is there a Device Package for Cat4507r ?
makkers
IS there a device package in CWorks LMS for the Cat4507's?
I have added 4 x Cat4507r's to our infra and cannot find a device package for the Cworks LMS.
We are running LMS v2.1.
Any advice much apprecaited.
Many thanks
Makkers
5 Replies 5
rmushtaq
Level 8
Level 8
CV device package?. If so, then check on CCO
Thx
Looked there but does not appear to be a package for CView, am I missing something?
Cant believe that there not a package for ths product.
The latest CV 6.0 package readme do list this device as supported. What CV version you're using?
Thx
we are using cv 5.4, cant see a link on cco for versin 6.0 if possible could you paste a link?
Many thanks for your input.
It is supported in the latest CV 5.4 device package as well: http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi
