NTP Doesnot Synchronize
manishthareja
Community Member
NTP Does not synchronise with windows 2000 server
here are the following outputs:
show NTP Association detail
x.x.234.10 configured, insane, invalid, stratum 2
ref ID 10.155.96.74, time C5AE743A.7C5D7957 (22:22:50.485 UTC Fri Feb 4 2005)
our mode client, peer mode server, our poll intvl 1024, peer poll intvl 1024
root delay 0.00 msec, root disp 1000.02, reach 377, sync dist 1270.569
delay 536.82 msec, offset 374420366059.2439 msec, dispersion 2.15
precision 2**7, version 3
org time C5AEA4FD.A6E978D4 (01:50:53.651 UTC Sat Feb 5 2005)
rcv time AF5D716F.DC75AF1E (12:11:27.861 UTC Fri Mar 26 1993)
xmt time AF5D716F.53080B8C (12:11:27.324 UTC Fri Mar 26 1993)
filtdelay = 536.82 537.48 535.98 536.12 538.27 566.15 575.56 558.35
filtoffset = 3744203 3744203 3744203 3744203 3744203 3744203 3744203 3744203
filterror = 0.02 0.03 0.05 0.06 0.08 0.09 0.11 0.12
show ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 381.4697 Hz, actual freq is 381.4697 Hz, precision is 2**17
reference time is 00000000.00000000 (00:00:00.000 UTC Mon Jan 1 1900)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
6 Replies 6
steve.busby
Level 10
Level 10
Here's a thread from a couple of weeks ago that may help you (Thanks Martin):
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dd73af0
A second, longer forum thread that also specifically details connecting to a W2K machine. Apparently it doesn't work so well. You can read about here:
I'd suggest what others have suggested, set-up a *nix NTP server or sync up with a Stratum 2 or 3 server on the internet.
r.bender
Community Member
Did you ever get this to work?
No. I was configuring it first time.
which chassis and what is your software ver.?
could you send ntp conf. lines.
druch
Level 2
Level 2
Windows 2000 works only as a SNTP server. You have to edit two registry key on your w2k system (server or prof. version):
HKEY LOCAL MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\
Parameters
LocalNTP = 1
ReliableTimeSource = 1
It's working on cisco routers supporting the sntp protocol. On platforms only supporting ntp, I've never seen it working.
r.bender
Community Member
I was trying to sync my 2950 switches with a Windows 2003 server with the NTP enabled and it is getting it's time from an Internet source but the switches did not like the server as a source. It considered it "insane" even though the switches see it as a Stratum 3 source. What is odd is that a PIX firewall I have likes it just fine.
I finally installed Tardis 2000 on the Windows 2003 server and the switches seem to like to sync with it now. Here is the link in case someone is interested in the program: http://www.kaska.demon.co.uk/
