Is there a MIB for IOSv routers?
SupportEngJohn
Does anyone know if there exists a MIB for IOSv routers? I tried looking in the MIB locator, https://mibs.cloudapps.cisco.com/ITDIT/MIBS/servlet/index, but can't seem to find one.
John
Francesco Molino
IOSv is simply the virtualization of IOS and used in Virl software (or others like EVE, GNS3...).
Personally I didn't do any snmp walk but it should be the same as standard IOS. You probably won't have access to all OIDs but the most important should be there.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
iacobansilviu1
Francesco is right.. To view to mib on the iosvl3 router issue: show snmp mib
