ISDN
jsheriony
hello.
when I tried to debug one of our cisco routers, I got the output below.
anyone know hwat it means??seem like an IOS bug..back up doesn't kick in..
May 7 15:53:33.992 UTC: ASSERTION FAILED: file "/vws/bvb/CPY-v123_8_t_throttle.V123_8_T11/vob/ios.sys7/sys/obj-5k-c2801/../chips/gt96k/gt96k_timer.c", line 771
May 7 15:53:34.196 UTC: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/3/0, TEI 110 changed to up
May 7 15:53:35.640 UTC: BRI0/3/0: wait for isdn carrier timeout, call id=0x852D
May 7 15:53:35.640 UTC: DDR: Dialing failed, 0 packets unqueued and discarded
May 7 15:53:37.820 UTC: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/3/0, TEI 110 changed to down
May 7 15:53:44.271 UTC: ASSERTION FAILED: file "/vws/bvb/CPY-v123_8_t_throttle.V123_8_T11/vob/ios.sys7/sys/obj-5k-c2801/../chips/gt96k/gt96k_timer.c", line 771
Richard Burts
Jayson
The messages about ASSERTION FAILED are certainly indications of a software problem. It is hard to know if these errors are related to the failure of the ISDN or whether there is some other problem with ISDN. But I would certainly look into a code update to fix the ASSERTION FAILED issue. After running different code then check again to see if ISDN is working better or not.
Rick
Rick
Hi Rick
thank a lot.
I suspected it to be an IOS bug and have aready
asked our engineers to analyze it and upgrade our IOS is necessary.
I needed to make sure if I looked into right...
thank you very much.
for the ISDN, looks like the ASSERTION FAILURE has been preventing the ISDN to kick in, and it also states that there's a problem with the ISDN telco.we need to do this step vy step, first by resolving the router problem.
Thanks a lot for your help
