06-15-2019 08:48 PM
Hi experts,
I'd like to integrate ISE and Mobileiron core and refer to the Cisco official guide, but it fails.
I just create an API role user in Mobileiron, and import Mobileiron certificate to ISE, then fill in all requiring integration information in ISE, like below:
The error warning below:
I used TCP dump in ISE to test the connection, it's normal.
I suspect the issue from the "Host Name / IP Address" field because I find all Mobileiron core hostname is "m.mobileron.net", I think ISE cannot identify which one is my Mobileiron.
Thanks for your reply
Best Regards
Solved! Go to Solution.
06-15-2019 09:20 PM
06-15-2019 09:20 PM
06-15-2019 10:09 PM
06-15-2019 10:18 PM
06-15-2019 10:24 PM
