ISE MDM: ISE and Mobileiron integration Issue
Sean Yuan
Hi experts,
I'd like to integrate ISE and Mobileiron core and refer to the Cisco official guide, but it fails.
I just create an API role user in Mobileiron, and import Mobileiron certificate to ISE, then fill in all requiring integration information in ISE, like below:
The error warning below:
I used TCP dump in ISE to test the connection, it's normal.
I suspect the issue from the "Host Name / IP Address" field because I find all Mobileiron core hostname is "m.mobileron.net", I think ISE cannot identify which one is my Mobileiron.
Thanks for your reply
Best Regards
Francesco Molino
Did you follow this documentation:
https://marketplace.mobileiron.com/servlet/servlet.FileDownload?file=00P3400001AwMyOEAV
It should be straight forward.
You can test your api access using postman with the fqdn and credentials you're configuring into ise for validation.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
thanks a lot for your help, but could you please let me know how to test API access?
Thanks again
On the link provided, there's a part where they showing how to test using postman application.
In few words, you'll put the credentials you're trying to configure info ise, do a get on a specific url (the beginning of the url should be the same as what you're trying to configure in ise) and then you should get an answer with some informations regarding the API version. See the page 13
Francesco
Thanks a lot for you help
