ISE policy sets hits refresh is too slow
CCC3
Hello.
The number of hits in the raise policy sets will be updated too late.
Originally, it should change in real time, but it seems to take more than 10 minutes, and it does not change immediately even if you are forced to refresh it.
The version is 3.2 patch 4.
10 minutes is quite a long time to adjust the counters, and when I looked at it, I "feel" it was much shorter. It is just a feeling because I never measured it. But it takes some time, especially if the PSN that took the session is not colocated with the PAN.
I often use pan/psn together while building several ise, but this is the first time I have experienced this kind of symptom.
Ruben Cocheno
@CCC3
Regardless of the size of the environment, it seems to be one of those things done by "design" which is frustrating sometimes
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
