ISE v2.4 Issue with Nexus 9318 switch
alanb
ISE Issue
Cisco ISE installed on VM (Hyper-V) machine
ISE Version 2.4
Setup iaw Cisco documentation
Two Cisco switches to be administered by ISE
  1. (MSW) Management SW (Cisco 2960)
  2. (ASW) Access SW Nexus Chassis - 9180YC-FX, SW nxos.7.0.3.I7.3.bin        (7.0(3)I7(3))
ISE Configured iaw LLD and Cisco Configuration Guides
For Evaluation and Testing
Profiles created for IOS and NXOS
Policy sets created for IOS and NXOS
External Identity Store (Active Directory) dl groups associated
Active Directory
AD Configured with 4 domain local groups, (dl-msw-admin, dl-msw-operator, dl-asw-admin, dl-asw-operator).
Users created and made members of dl groups
Switches Configured iaw Cisco Config guide
ASW (NXOS) NX 9318 V7.0(3)
feature tacacs+
ip tacacs source-interface mgmt0
tacacs-server host w.x.y.z key 7 "afhjiiwke"
aaa group server tacacs+ AAAservers
    server w.x.y.z
    use-vrf management
aaa authentication login default group AAAservers local
aaa authorization config-commands default group AAAservers local
aaa authorization commands default group AAAservers local
aaa accounting default group AAAservers
tacacs-server directed-request
interface mgmt0
  vrf member management
  ip address w.x.y.z/24
Problem
When trying to log in using credentials (username, password), from AD
Management SW (2960) works correctly, authenticates and authorises using Active directory data.
Access SW (9318) has problem
Access is denied.
ISE logging shows Authentication correct, but no Authorisation takes place.
Different users, password, and groups tried with same result.
On ASW switch can ping ISE correctly
Test aaa server tacacs+ w.x.y.z vrf management username password
And Test aaa group AAAservers username password
Give response -- error authenticating to server, status 7
No obvious indication from debug tacacs+
I am running with the ISE 90 day evaluation licence, for testing, could this be an issue?
I have noticed that the Cisco ISE (v2.4) - Network Component Compatibility document  has no Nexus devices listed, could this be an issue?
Grateful for any suggestions?
Alan (Network Design Engineer)
0 Replies 0
