02-24-2019 03:01 AM
I having a hardtime configuring my devices to connect through internet, my router reached the isp but switch can't reached. I plugged my pc in switch and no internet access. Here's my configuration.
ISP ADDRESS : 24.50.185.72/29
GATEWAY : 24.50.185.73
ROUTER :
G0/0/0 : 24.50.185.74/29
IP ROUTE TO : 24.50.185.73
G0/0/1 : VLAN 10 10.1.1.1/24
VLAN 20 10.1.2.1/24
VLAN 30 10.1.3.1/24
SWITCH :
G1/0/24 : SWITCHPORT TRUNK
SWITCHPORT ACCESS VLAN 10
G1/0/1 : SWITCHPORT ACCESS VLAN 20
G1/0/2 : SWITCHPORT ACCESS VLAN 30
Still my segment doesn't reached the other segment and no internet.
Thank you in advance.
Solved! Go to Solution.
02-24-2019 08:38 AM
What is the default gateway on PC1? It must be 10.1.2.1
What is the default gateway onPC2? It must be 10.1.3.1
Ping from PC1 to 10.1.2.1
Ping From PC2 to 10.1.3.1
and share the result.
Deepak Kumar
02-24-2019 09:23 AM
02-24-2019 11:10 AM
02-24-2019 12:08 PM
02-24-2019 08:37 PM
