ISR 4000 series EOL
frybeck25
With the 4000 series of the ISR's end of lifeing over the next few years, what is a good option for just phone services? (CUBE, SRST and FXO ports)
Most of my 4000's are just used as an FXO port to talk to some analog equipment and SRST for emergency analog phone lines. i am looking on Cisco's website and they are pointing me to the C8200-1N-4T but that one only has one NIM slot so cant have a DSP and a FXO port on it.
M02@rt37
Hello @frybeck25
Please check table 2 in this document [https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8300-series-edge-platforms/datasheet-c78-744088.html]. C8200 and 8300 series are the right choice now for you. Find the specific model that fit your need in term of NIM ports and others...
Best regards
