Set up TACACS on Nokia equipment using ISE
CCC3
You want to use ISE to set up TACACS on Nokia equipment.
Since it is a third-party equipment, I understand that a separate value must be added to the tacacs profile.
What values should be added to the custom attributes
If you know it, please answer.
Nokia equipment seems to be Nokia 7750 SR(?).
difficult to find a comprehensive guide on how to integrate ISE and TACACS with third part vendors. I did find the article below, maybe you can translate the router settings to ISE...
https://www.thingnetwork.io/tacacs-authentication-with-nokia-service-routers/
