06-12-2018 05:20 AM - edited 03-01-2019 06:38 PM
Hello supportforums!
Got a Cisco ISR 4431 SEC-K9
ISR#show version Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1) System image file is "bootflash:isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
with a NIM-ES2-4
module installed
All 4 interfaces of that module are configured in access mode in a VLAN 23, up and running.
I configured FNF on the router, those are configurations for flow records:
ISR#show flow record NETFLOW
flow record NETFLOW:
Description: User defined
No. of users: 1
Total field space: 55 bytes
Fields:
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match transport tcp source-port
match transport tcp destination-port
match transport udp source-port
match transport udp destination-port
match interface input
match flow direction
match application name
collect interface output
collect counter bytes
collect counter packets
collect connection initiator
collect connection client ipv4 address
collect connection client transport port
collect connection server ipv4 address
collect connection server transport port
ISR# show flow record NETFLOW_OUT
flow record NETFLOW_OUT:
No. of users: 1
Fields:
match ipv4 protocol
match interface output
collect interface input
which are bound to flow monitors:
ISR#show run flow monitor NETFLOW Current configuration: ! flow monitor NETFLOW exporter PRTG cache timeout inactive 60 cache timeout active 60 cache timeout update 60 record NETFLOW ! ISR#show run flow monitor NETFLOW_OUT Current configuration: ! flow monitor NETFLOW_OUT exporter PRTG cache timeout inactive 60 cache timeout active 60 cache timeout update 60 record NETFLOW_OUT !
using the same exporter.
Now i have that VLAN 23 interface on which i apply flow monitors on both directions:
ISR#show run int vlan 23 Building configuration... Current configuration : 196 bytes ! interface Vlan23 description ----- ip address 172.16.23.102 255.255.255.0 ip nat inside ip flow monitor NETFLOW input ip flow monitor NETFLOW_OUT output ip virtual-reassembly end
THe problem is that there are no entries when i run:
ISR#show flow monitor NETFLOW_OUT cache format table Cache type: Normal (Platform cache) Cache size: 200000 Current entries: 0 Flows added: 0 Flows aged: 0 There are no cache entries to display.
I understand that if that were configured on physical interface, it would be working, as on our other ISR 4321 routers, even with one flow record and monitor, i just decided to go with separated records and monitors, just to check if it works for me.
The question: is it possible to configure both input and output netflow on VLAN interface, or a router worth 14000$ is not capable to do such a thing?
06-13-2018 11:11 PM
Any Cisco representative here?
So an old Cisco 871 with
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(24)T8, RELEASE SOFTWARE (fc1)
can do such a thing, but a 4400 series ISR can not?
06-19-2018 11:45 PM
Sad story.
12-05-2019 10:41 AM - edited 12-05-2019 10:42 AM
In order to provide a response to this query for the record
Unfortunately there is not a lot of information about this limitation by researching on old codes, however on latest documents cisco has included this limitation:
Flexible NetFlow is not supported on Switch Virtual Interface (SVI)
12-08-2019 11:50 PM
What a shame.
Here is output from one of Cisco 871:
c800_R14#show run int vlan 1 Building configuration... Current configuration : 402 bytes ! interface Vlan1 description LAN ip address 172.16.46.1 255.255.255.0 ip flow monitor NETFLOW input ip flow monitor NETFLOW output ip nat inside ip virtual-reassembly rate-limit input access-group 199 2048000 64000 64000 conform-action transmit exceed-action drop rate-limit output access-group 199 2048000 64000 64000 conform-action transmit exceed-action drop ip tcp adjust-mss 1452 end
c800_R14#show version Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(24)T8, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2012 by Cisco Systems, Inc. Compiled Sun 09-Sep-12 09:09 by prod_rel_team ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE c800_R14 uptime is 2 weeks, 5 days, 20 hours, 24 minutes System returned to ROM by power-on System restarted at 13:16:43 EET Tue Nov 19 2019 System image file is "flash:c870-advsecurityk9-mz.124-24.T8.bin"
It's somewhat funny and sad at the same time that an old router can do it, and a new one can't
c800_R14#show flow monitor NETFLOW cache
Cache type: Normal
Cache size: 4096
Current entries: 702
High Watermark: 2395
Flows added: 7766545
Flows aged: 7765843
- Active timeout ( 60 secs) 7765800
- Inactive timeout ( 60 secs) 43
- Event aged 0
- Watermark aged 0
- Emergency aged 0
IPV4 SRC ADDR IPV4 DST ADDR TRNS SRC PORT TRNS DST PORT TCP SRC PORT TCP DST PORT UDP SRC PORT UDP DST PORT INTF OUTPUT FLOW DIRN IP PROT intf input bytes pkts
52.109.124.22 172.16.46.19 443 49556 443 49556 0 0 Vl1 Output 6 Fa4 40 1
172.16.46.51 172.16.1.132 63060 53 0 0 63060 53 Null Input 17 Vl1 66 1
172.16.1.132 172.16.46.51 53 63060 0 0 53 63060 Vl1 Output 17 Fa4 82 1
172.16.46.51 172.217.18.106 55041 443 0 0 55041 443 Fa4 Input 17 Vl1 6982 6
172.16.46.2 40.74.32.146 53604 443 53604 443 0 0 Fa4 Input 6 Vl1 2978 6
40.74.32.146 172.16.46.2 443 53604 443 53604 0 0 Vl1 Output 6 Fa4 669 4
172.16.1.20 172.16.46.247 46138 80 46138 80 0 0 Vl1 Output 6 Fa4 279 6
172.16.46.247 172.16.1.20 80 46138 80 46138 0 0 Null Input 6 Vl1 1872 18
172.16.46.51 172.217.22.99 49484 443 49484 443 0 0 Fa4 Input 6 Vl1 965 9
172.217.22.99 172.16.46.51 443 49484 443 49484 0 0 Vl1 Output 6 Fa4 5243 8
172.16.46.28 172.16.1.206 63386 53 0 0 63386 53 Null Input 17 Vl1 66 1
172.16.1.206 172.16.46.28 53 63386 0 0 53 63386 Vl1 Output 17 Fa4 82 1
172.16.46.28 172.16.1.206 50606 53 0 0 50606 53 Null Input 17 Vl1 66 1
172.16.1.206 172.16.46.28 53 50606 0 0 53 50606 Vl1 Output 17 Fa4 82 1
172.16.46.28 172.16.1.206 53029 53 0 0 53029 53 Null Input 17 Vl1 66 1
172.16.1.206 172.16.46.28 53 53029 0 0 53 53029 Vl1 Output 17 Fa4 123 1
172.16.1.190 172.16.46.28 80 50447 80 50447 0 0 Vl1 Output 6 Fa4 425 6
23.111.104.36 172.16.46.24 443 51912 443 51912 0 0 Vl1 Output 6 Fa4 2062 7
172.16.46.24 88.212.236.148 51913 443 51913 443 0 0 Fa4 Input 6 Vl1 3574 50
88.212.236.148 172.16.46.24 443 51913 443 51913 0 0 Vl1 Output 6 Fa4 135940 97
172.16.46.24 95.213.182.98 51914 443 51914 443 0 0 Fa4 Input 6 Vl1 1607 10
95.213.182.98 172.16.46.24 443 51914 443 51914 0 0 Vl1 Output 6 Fa4 1682 8
172.16.46.26 172.16.1.190 61070 80 61070 80 0 0 Null Input 6 Vl1 1363 6
172.16.1.190 172.16.46.26 80 61070 80 61070 0 0 Vl1 Output 6 Fa4 578 5
