Issue with adding description to interface on a switch (using PT)
chukwuma
USING PACKE TRACER,
AFTER ISSUING THIS COMMANDS:
AZ-SWO1(config)#int gig 1/0/1
AZ-SWO1(config-if)#des
AZ-SWO1(config-if)#description "CONNECT TO AZ-SW03 FAS0/2"
AZ-SWO1(config-if)#
AZ-SWO1(config-if)#^Z
AZ-SWO1#
I NOW RUN SHOW INTERFACE STATUS. BUT THE DESCRIPTION DO NOT APPEAR ON THE LINE HERE:
AZ-SWO1#show int sta
Port      Name    Status    Vlan   Duplex   Speed   Type
Gig1/0/1          connected 1      auto      auto   10/100BaseTX
Gig1/0/2          connected 1      auto      auto   10/100BaseTX
Gig1/0/3          connected 1      auto      auto   10/100BaseTX
PLEASE I NEED HELP.
THANKS
2 Accepted Solutions
Georg Pauwen
odd. What version of Packet Tracer is this on ?
I am using the latest (8.1.1):
Switch(config)#interface gigabitEthernet 1/0/3
Switch(config-if)#description "CONNECT TO AZ-SW03 FAS0/2"
Switch(config-if)#^Z
Switch#
%SYS-5-CONFIG_I: Configured from console by console
Switch#sh interfaces status
Gig1/0/1 "Interface" notconnect 1 auto auto 10/100BaseTX
Gig1/0/2 "CONNECT TO AZ-SW0 notconnect 1 auto auto 10/100BaseTX
Gig1/0/3 "CONNECT TO AZ-SW0 notconnect 1 auto auto 10/100BaseTX
I don't know if it is a version problem.
Check the link below for the latest version:
https://www.computernetworkingnotes.com/ccna-study-guide/download-packet-tracer-for-windows-and-linux.html
5 Replies 5
Georg Pauwen
Switch#
i am using version 8.0.0.0212.
if i need an upgrade. please how do i go about it
thanks
Hello
I updated to the latest version and it is solve.
Thanks a lot
Hello
Thank you
