Issue with Cisco solicited IOS CLI commands
vanoordtm
So I'm trying to reload the router with EEM.  However, I want it done via cli action statement, so I can delay the reload in 10.  However, I'm having issues with the pattern keyword.  Below is my applet and the debug.  It seems the pattern statement is not answering the solicited question.  I've tried several different combinations, but the one below makes the most sense to me.
event manager applet TEST
event none
action 1.0 syslog msg "Reload Router"
action 1.1 cli command "enable"
action 1.3 cli command "reload in 10" pattern "yes"
action 1.5 cli command "confirm"
action 1.7 syslog msg "It worked!!!"
*Mar  1 00:37:18.831: %HA_EM-6-LOG: TEST: Reload Router
*Mar  1 00:37:18.839: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_open called.
*Mar  1 00:37:18.939: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT :
*Mar  1 00:37:18.939: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : R2>
*Mar  1 00:37:18.939: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : R2>enable
*Mar  1 00:37:18.955: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT :
*Mar  1 00:37:18.955: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : R2#
*Mar  1 00:37:18.955: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : R2#reload in 10
*Mar  1 00:37:18.967: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : confirm
R2#
R2#
*Mar  1 00:37:38.879: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT :
*Mar  1 00:37:38.879: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : % Please answer 'yes' or 'no'.
*Mar  1 00:37:38.879: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : System configuration has been modified. Save? [yes/no]:
*Mar  1 00:37:38.879: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_close called.
The Manual Way:
R2#reload in 10
System configuration has been modified. Save? [yes/no]: yes
Building configuration...
[OK]
Reload scheduled in 10 minutes by console
Reload reason: Reload Command
Proceed with reload? [confirm]
R2#
*Mar  1 00:56:27.083: %SYS-5-SCHEDULED_RELOAD: Reload requested for 01:06:22 UTC Fri Mar 1 2002 at 00:56:22 UTC Fri Mar 1 2002 by console. Reload Reason: Reload Command.
I even tried this:
event none
action 1.2 cli command "wr"
action 1.3 cli command "reload in 10" pattern "confirm"
end
R2#
R2#
R2#event manager run TEST
*Mar  1 00:54:52.855: %HA_EM-6-LOG: TEST: Reload Router
R2#
*Mar  1 00:54:52.863: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_open called.
*Mar  1 00:54:52.963: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT :
*Mar  1 00:54:52.963: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : R2>
*Mar  1 00:54:52.963: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : R2>enable
*Mar  1 00:54:52.979: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT :
*Mar  1 00:54:52.979: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : R2#
*Mar  1 00:54:52.979: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : R2#wr
*Mar  1 00:54:53.895: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT :
*Mar  1 00:54:53.899: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Building configuration...
*Mar  1 00:54:53.899: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : [OK]
*Mar  1 00:54:53.899: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : R2#
*Mar  1 00:54:53.903: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : R2#reload in 10
*Mar  1 00:54:54.015: %HA_EM-6-LOG: TEST: It worked!!!
R2#
*Mar  1 00:54:54.015: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_close called.
Joe Clarke
Your second approach is good, but you're not answering the prompt.  Add:
action 1.8 cli command "y"
Joe Clarke
Should I expect the debug to print the Pattern response??
You should see whatever IOS typically prints out.
