06-26-2020 06:55 AM - edited 06-29-2020 11:54 PM
Hello community,
I am trying to use the config copy mib for conf updates. While it works great using tftp, I have an issue with scp and I fail to see where I am wrong. From CLI, both TFTP and SCP do work as expected.
Hardware is 2960X running 15.0(2)EX5
Working TFTP test:
ccopy@syslog:~ % cat /tftpboot/test.conf
int lo6
description test-conf-copy-mib-TFTP
end
ccopy@syslog:~ % ./confcopy tftp
CISCO-CONFIG-COPY-MIB::ccCopyProtocol.88912 = INTEGER: tftp(1)
CISCO-CONFIG-COPY-MIB::ccCopySourceFileType.88912 = INTEGER: networkFile(1)
CISCO-CONFIG-COPY-MIB::ccCopyDestFileType.88912 = INTEGER: runningConfig(4)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddress.88912 = IpAddress: A.B.C.D
CISCO-CONFIG-COPY-MIB::ccCopyFileName.88912 = STRING: test.conf
CISCO-CONFIG-COPY-MIB::ccCopyUserName.88912 = STRING: ccopy
CISCO-CONFIG-COPY-MIB::ccCopyUserPassword.88912 = STRING:
CISCO-CONFIG-COPY-MIB::ccCopyNotificationOnCompletion.88912 = INTEGER: false(2)
CISCO-CONFIG-COPY-MIB::ccCopyState.88912 = INTEGER: successful(3)
CISCO-CONFIG-COPY-MIB::ccCopyTimeStarted.88912 = Timeticks: (1728626846) 200 days, 1:44:28.46
CISCO-CONFIG-COPY-MIB::ccCopyTimeCompleted.88912 = Timeticks: (1728627647) 200 days, 1:44:36.47
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88912 = INTEGER: active(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressType.88912 = INTEGER: ipv4(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressRev1.88912 = STRING: "A.B.C.D"
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88912 = INTEGER: destroy(6)
ccopy@syslog:~ % snmpwalk -v2c -c c0mUn1tY X.Y.Z.T ifName | grep Lo
IF-MIB::ifName.14067 = STRING: Lo6
ccopy@syslog:~ % snmpwalk -v2c -c c0mUn1tY X.Y.Z.T ifAlias | grep copy-mib
IF-MIB::ifAlias.14067 = STRING: test-conf-copy-mib-TFTP
log on switch:
Jun 26 12:46:29.328: %SYS-5-CONFIG_I: Configured from tftp://A.B.C.D/test.conf by console
Jun 26 12:46:31.328: %LINK-3-UPDOWN: Interface Loopback6, changed state to up
Jun 26 12:46:32.338: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback6, changed state to up
Doing the same with SCP ends in error. SCP transfer to running works with the CLI
ccopy@syslog:~ % cat test.conf
int lo7
description test-conf-copy-mib-SCP
end
ccopy@syslog:~ % ./confcopy scp
CISCO-CONFIG-COPY-MIB::ccCopyProtocol.88971 = INTEGER: scp(4)
CISCO-CONFIG-COPY-MIB::ccCopySourceFileType.88971 = INTEGER: networkFile(1)
CISCO-CONFIG-COPY-MIB::ccCopyDestFileType.88971 = INTEGER: runningConfig(4)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddress.88971 = IpAddress: A.B.C.D
CISCO-CONFIG-COPY-MIB::ccCopyFileName.88971 = STRING: test.conf
CISCO-CONFIG-COPY-MIB::ccCopyUserName.88971 = STRING: ccopy
CISCO-CONFIG-COPY-MIB::ccCopyUserPassword.88971 = STRING:
CISCO-CONFIG-COPY-MIB::ccCopyNotificationOnCompletion.88971 = INTEGER: false(2)
CISCO-CONFIG-COPY-MIB::ccCopyState.88971 = INTEGER: failed(4) <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
CISCO-CONFIG-COPY-MIB::ccCopyTimeStarted.88971 = Timeticks: (1728676853) 200 days, 1:52:48.53
CISCO-CONFIG-COPY-MIB::ccCopyTimeCompleted.88971 = Timeticks: (1728676869) 200 days, 1:52:48.69
CISCO-CONFIG-COPY-MIB::ccCopyFailCause.88971 = INTEGER: badFileName(2) <<<<<<<<<<<<<<<<<<<<
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88971 = INTEGER: active(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressType.88971 = INTEGER: ipv4(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressRev1.88971 = STRING: "A.B.C.D"
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88971 = INTEGER: destroy(6)
ccopy@syslog:~ %
SWITCH#sh int desc | i SCP
SWITCH#
SWITCH#copy scp://ccopy@A.B.C.D/test.conf running-config
Destination filename [running-config]?
Password for ccopy@syslog:
Sending file modes: C0644 47 test.conf
47 bytes copied in 6.407 secs (7 bytes/sec)
SWITCH#
Jun 26 12:55:54.439: %SYS-5-CONFIG_I: Configured from scp://ccopy@A.B.C.D/test.conf by cisco on vty0 (A.B.C.D)
Jun 26 12:55:55.443: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback7, changed state to up
Lo7 up up test-conf-copy-mib-SCP
SWITCH#
Well... I am a bit puzzled. If someone can shed some light on this, it would be very appreciated :-)
Solved! Go to Solution.
06-26-2020 10:59 PM
- Check and or turn on verbose logging for the remote sshd-server, then see what is reported when you try confcopy with the scp protocol
M.
06-30-2020 12:23 AM
Thanks for looking into this. Your suggestion directed me straight to the root cause: SSH authentication issue, the agent doesn't know about keyboard-interactive method. I had to enable the old builtin pwd auth mechanism.
For those not familiar with OpenSSH, it is option 'PasswordAuthentication=yes'
06-26-2020 10:59 PM
M.
06-30-2020 12:23 AM
06-30-2020 12:38 AM
- Good work !
M.
06-30-2020 01:05 AM
Thanks Marce !
06-30-2020 01:28 AM
- Please mark thread as resolved , not so much for myself but for those who browse subjects on the forum and or later indexing in search engines too.
M.
