java error on cat3750
joris.everaert
Community Member
Deviceview on all components is running fine, however, we have one cat 3750 stack, that generates an error when trying to configure a port (switch config works fine).
The error generated is "failed to create dialog due to java.lang.nullpointerException".
Anyone an idea on how to start to solve the problem ?
Thanks.
David Stanford
Are you getting this error in CiscoView? If so, what device package version are you running and what version of IOS?
