03-15-2010 03:27 AM
hello,
I'm getting the attached error when accessing only the device discovery page from Common Services ( CS version 3.1.1)
Please advise asap
03-15-2010 12:48 PM
It looks like you have a problem with your installation. I recommend you contact TAC so they can inspect the files, and make sure they are consistent with a working server.
03-15-2010 12:56 PM
Hi Jose,
I solved the issue by applying one of the CS discovery patches( apparently it replaced somehow one of the corrupted libraries or jsp files)
Thx anyways
