Shutdown wireless interface via SNMP Write?
jasonhumes
Level 5
Level 5
We're working on writing a very simple web app to control a couple of access points via SNMP.  I'm trying to shutdown the Wireless interface via SNMP WRITE with the following oid;
.1.3.6.1.2.1.2.2.1.7.1
and
.1.3.6.1.2.1.2.2.1.7.2
But its saying the integer of '0' is invalid (badValue, wrong type or length).  I'm able to set other values like hostname, etc, so I know my string is correct...can anyone help?  THanks
Jason
jasonhumes
Level 5
Level 5
Just found my own answer...the value to shutdown the interface is not 0, it's 2.  durrr
J
