Java error on LMS 3.0.1
k.abillama
Level 3
Level 3
hello,
I'm getting the attached error when accessing only the device discovery page from Common Services ( CS version 3.1.1)
Please advise asap
Joe Clarke
It looks like you have a problem with your installation.  I recommend you contact TAC so they can inspect the files, and make sure they are consistent with a working server.
Hi Jose,
I solved the issue by applying one of the CS discovery patches( apparently it replaced somehow one of the corrupted libraries or jsp files)
Thx anyways
