Job Approval WorkFlow for Cisco Prime Infrastructure 2.0
Aldo Insfran
Hi all,
I'm trying to configure the Job Apporval feature in the CPI-2.0, doing the following;
-Enabling the feature for all jobs in, Administration > System Settings > Job Approval Settings,
-Then, creating users without the permission for approving jobs,
But, using the credentials of those who doesn't have approval permission, I still can perform all jobs,
-Discovery,
-Config, Rollback, Overwrite,
-Create, Deploy Templates, etc,
Is there any "Job Approval WorkFlow for Cisco Prime Infrastructure 2.0" documentation that can help me configuring this feature?
Can somebody help with this?
Thanks in advance,
AFROJ AHMAD
Hi ,
Administration > System Settings > Job Approval Settings.
Enable Job Approval check box
then click Add and the enter that command   " CONFIG\\w*  "
to enable job approval for all job types starting with Config.
Hope it will help
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
