Prime Infrastructure delegate specific config changes - wireless controller
tbostrom
I have a customer that would like to delegate control for two items on a WLC to a sub-group within their organization.  They'd like to allow this group to change the PSK on a specific WLAN on their WLC 5508 and also add/remove/change mac addresses from the Mac Filter list whenever necessary.
They'd like to restrict the group to only be able to make these two specific changes and not be able to change anything else on the controller.  Is there a way in PI to restrict this group so that they can only make these changes?
I can see that in 2.0 I can require job approval which may work as some part of the restriction.
Any thoughts/ideas/help?
fb_webuser
Level 11
Level 11
add a new group (choose on of the user defined groups). Mark the options you want to have. (network configuration)
Posted by WebUser Erik Boss from Cisco Support Community App
Aldo Insfran
Community Member
Hi tbostrom,
Did you solved this issue, and make this job approval scheme work?
I have a similar problem here it seems not to work in CPI-2.0,
