05-18-2022 11:49 PM
Hi everyone,
the issue is not new - some jobs have a next-start date in the past. This is effects also system poller jobs, which cannot be restarted/-scheduled.
Do someone know which logfile to look at to get some information what might be the root-cause? jobManager.log just shows details about jobs that did run, not the ones that did not
05-19-2022 01:24 AM
If you can open a tac, why not?
But, if can try to dig by yoursefl, you can search in /opt/CSCOlumos/logs/ using the shell mode.
01-23-2023 08:14 AM
Did you get any response from TAC or solution? I have an open case but searching for more info. I noticed that all the network devices have status = PING REACHABLE when the jobs do not run so a manual sync is required but obviously we do not want that.
