Cisco Switch 3850, and problem with FlexFlow, date 1970-01-01
Hi, as you can read in title, I have problem with Cisco Switch 3850, and Nagios NA (netflow) I try with nfdump, and I saw, bad date, and time, I do not know how to fix that, I try something, but, without any improving...:(
root@localhost 3850]# nfdump -r nfcapd.201412041035
Date first seen Duration Proto Src IP Addr:Port Dst IP Addr:Port Packets Bytes Flows
1970-01-01 01:00:00.000 0.000 UDP 10.145.192.18:123 -> 10.250.72.44:123 1 100 1
1970-01-01 01:00:00.000 0.000 TCP 10.193.1.230:80 -> 10.250.72.36:57205 1 50 1
1970-01-01 01:00:00.000 0.000 TCP 10.250.68.46:445 -> 10.250.72.31:52423 317 67461 1
1970-01-01 01:00:00.000 0.000 TCP 10.145.192.19:445 -> 10.250.72.71:59686 9 1835 1
1970-01-01 01:00:00.000 0.000 TCP 10.x.x.x:5061 -> 10.250.72.33:63912 3 548 1
1970-01-01 01:00:00.000 0.000 TCP 173.xxx.xxx.65:80 -> 10.250.72.41:62692 6 330 1
I try this, ....grrr
https://supportforums.cisco.com/document/24156/router-log-timestamp-entries-are-different-system-clock-when-ntp-configure
Any help?
This is configuration, from switch 3580
flow record NAGIOS
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes long
collect counter packets long
collect timestamp absolute first
collect timestamp absolute last
flow exporter NAGIOS
destination 10.250.72.111
source Vlan 68
transport udp 9996
template data timeout 60
flow monitor NAGIOS
exporter NAGIOS
cache timeout active 60
record NAGIOS
vlan configuration 68
ip flow monitor NAGIOS input
CCNA R&S, CCNA Security
11 Replies 11
Marvin Rhoads
Can you check on the switch to see what it thinks the timestamps are?
For example:
show flow monitor NAGIOS cache sort highest counter packets
This is output....
3850_P1_ZA#show flow monitor NAGIOS cache sort highest counter packets l
3850_P1_ZA#show flow monitor NAGIOS cache sort highest counter packets long
Processed 8442 flows
Aggregated to 8442 flows
Showing the top 20 flows
IPV4 SOURCE ADDRESS:       10.216.0.7
IPV4 DESTINATION ADDRESS:  10.250.72.87
TRNS SOURCE PORT:          8080
TRNS DESTINATION PORT:     51919
INTERFACE INPUT:           Gi1/0/14
IP TOS:                    0x30
IP PROTOCOL:               6
interface output:          LIIN0
counter bytes long:        14785874
counter packets long:      9832
timestamp abs first:       06:52:38.828
timestamp abs last:        06:53:07.828
IPV4 SOURCE ADDRESS:       69.64.57.45
IPV4 DESTINATION ADDRESS:  10.250.72.38
TRNS DESTINATION PORT:     51791
IP TOS:                    0x48
IP PROTOCOL:               6
counter bytes long:        10765150
counter packets long:      7159
timestamp abs first:       06:31:29.828
timestamp abs last:        06:32:24.828
Does your switch have a valid ntp association and date setting?
show ntp assoc
show clock
Everything looks nice....
3850_P1_ZA#show ntp associations
  address         ref clock       st   when   poll reach  delay  offset   disp
 ~10.145.192.14   .INIT.          16      -   1024     0  0.000   0.000 15937.
 * sys.peer, # selected, + candidate, - outlyer, x falseticker, ~ configured
3850_P1_ZA#show clock
*23:48:40.936 CET Fri Dec 5 2014
3850_P1_
Actually your NTP is configured but not synced. The tilde (~) indicates that.
Also, the asterisk before your clock time is another indicator that the time is not NTP-synced.
What I can to do ? I found some problems, they do not have  connection whit this problem, I will fix in monday, I will look in doc about NTP, is this maybe source of my problem with nagios ?
It may very well be although I am not certain.
It would seem to make sense since your flow record is looking to get definitive time (since the Unix epoch) but your switch does not have a synchronized clock.
Time form sh clock and etc is right....This photo is from switch, I used Wireshark,  and that time, was right.... :)
So the packets seen leaving the switch have a correct accurate timestamp (albeit perhaps not NTP-synced).
That would tell me that the issue is at the Nagios end not correctly parsing that information out of the received packets.
I found wrong time with another program, nfdump.... I think, cisco switch 3850 has some problem with compatibility....cisco and nagios,nfdump
I had a similar problem with a cisco ASR1000. In my case the problem was in the nfdump reader which was not reading the files correctly. I noticed this because I had an output like this:
Skip nsel extension: '20' - nsel options not compiled
Skip nsel extension: '22' - nsel options not compiled
Skip nsel extension: '25' - nsel options not compiled
1970-01-01 01:00:00.000     00:00:00.000 UDP      100.64.136.89:50380 ->          0.0.0.0:0            0    0     1
To fix this I recompiled nfdump adding nsel support.
./configure --enable-nfprofile --enable-nftrack --enable-nel
So you may have the correct data in the files. It could be nfdump failing to read them properly.
Gianrico Fichera
