LACP question
AlexM12
Community Member
Hi guys I am a newbie here. I am planning to take my CCNA exam next month. However I had encountered a problem regarding LACP.
All my configurations are well and running until I added LACP in my network or different etherchannel versions in my activity just for the sake of practicing.
Well now, if my ports are bundled together, do they still participate in STP? If not why do my switches are blocking the ports when attempting "sh span" command? Also I cannot ping my switch with the block ports in it.
Actually before experiencing this problem, it was working well with LACP configurations added in my network. The thing is my packet tracer keeps on shutting down so I had to reopen again my activity for a few times. Then after doing it, the problem occurs.
Switch8#sh span
VLAN0010
Spanning tree enabled protocol ieee
Root ID Priority 32778
Address 0001.6302.894C
Cost 9
Port 28(Port-channel 2)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32778 (priority 32768 sys-id-ext 10)
Address 00E0.B022.B556
Aging Time 20
Interface Role Sts Cost Prio.Nbr Type
Po1 Altn BLK 9 128.27 Shr
Po2 Root FWD 9 128.28 Shr
VLAN0020
Root ID Priority 32788
Cost 9
Bridge ID Priority 32788 (priority 32768 sys-id-ext 20)
Aging Time 20
Fa0/2 Desg FWD 19 128.2 P2p
Fa0/1 Desg FWD 19 128.1 P2p
VLAN0030
Root ID Priority 32798
Cost 9
Bridge ID Priority 32798 (priority 32768 sys-id-ext 30)
Aging Time 20
Fa0/3 Desg FWD 19 128.3 P2p
Fa0/4 Desg FWD 19 128.4 P2p
Switch8#sh etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SU) LACP Fa0/6(P) Fa0/7(P)
2 Po2(SU) LACP Fa0/10(P) Fa0/11(P)
Switch8#sh etherchannel port-channel
Channel-group listing:
Group: 1
Port-channels in the group:
Port-channel: Po1 (Primary Aggregator)
Age of the Port-channel = 00d:00h:11m:41s
Logical slot/port = 2/1 Number of ports = 2
GC = 0x00000000 HotStandBy port = null
Port state = Port-channel
Protocol = LACP
Port Security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Fa0/7 Passive 0
0 00 Fa0/6 Passive 0
Time since last port bundled: 00d:00h:11m:41s Fa0/6
Group: 2
Port-channel: Po2 (Primary Aggregator)
Logical slot/port = 2/2 Number of ports = 2
Protocol = LACP
0 00 Fa0/10 Active 0
0 00 Fa0/11 Active 0
Time since last port bundled: 00d:00h:11m:40s Fa0/11
omz
I think the topology is too big for packet tracer hence the reason it keeps crashing.
Create a smaller topology with only 3 switches to understand the LACP and STP behaviour.
When 2 links are connected between the same switches, STP blocks 1 of them.
The same 2 links in a port-channel, STP treats as a 1 link (port-channel).
If 3 switches are connected with port-channels in a loop, STP will block a port-channel to avoid loops.
AlexM12
Community Member
oh okay. So meaning they still participate in STP.
I have one more question. Why can't I ping the switch using the management VLAN. Should I also include my native VLAN in the allowed VLANS in the trunk ports?
By default, the native VLAN is allowed on the trunk. Unless switchport trunk allowed vlan x is configured. If the native VLAN is changed from the default VLAN 1 and not allowed on the trunk then it should be allowed. Yes you should allow the native VLAN on the trunk if that's the management VLAN as well and the ping is to a management address.
