08-11-2021 04:15 AM
- 90 Mb MTNL leased line is frequently disconnect in router ethernet port in 1 or 2 hrs.
- Then start working if we physically remove and refix cable.
- Other 90 Mb Railtel leased line is working fine on same port.
- But same line is working fine when connected with Laptop with out any issue.
- Tried ethernet port swap in router and in l2 switch provided by Exchange.
Router ports config details
interface GigabitEthernet0/3
description LL - 90 Mbps PDUUB_DLI - SM6_DLI_MTNL
bandwidth 92160
ip address 10.205.49.162 255.255.255.252
ip flow ingress
ip flow egress
ip pim sparse-dense-mode
rate-limit input access-group 10 20480000 20480 20480 conform-action transmit exceed-action drop
rate-limit output access-group 10 20480000 20480 20480 conform-action transmit exceed-action drop
ip igmp join-group 238.192.238.192
ip ospf network point-to-point
ip ospf mtu-ignore
ip ospf cost 4
duplex auto
speed auto
no cdp enable
08-11-2021 04:20 AM
what router is this ? and what IOS running ?
Can you post - show interface gi 0/3 ( see any Drops here ?) what L2 Switch ? do you have acces - see any Logs ?
what you see Logs on the router when you lost connection before remove cable and plug the cable ?
08-11-2021 08:09 AM
hard to tell. Is the rate limiting mandatory ? You might want to try traffic shaping instead (if your IOS and router supports this).
Remove the lines:
from the interface, and add the below to your configuration (the exact syntax on your device might differ):
policy-map SHAPE_90
class class-default
shape average 90000000
service-policy output SHAPE_90
