11-29-2019 01:16 AM
We have a problem with the Cisco Prime license that we have already purchased, the license we should inject into the server is the Cisco prime infrastructure license but when it is injected what appears is the Cisco Prime Infrastructure Operation Center instead of the Cisco Prime Infrastructure
Has anyone ever experienced something similar? and is there a solution?
11-29-2019 02:25 AM
- It was probably ordered with a wrong PAK (license type) ; contact your re-seller or CISCO (direct) to correct this. I think there is an address called licensing@cisco.com where you may want to forward this question too.
M.
11-29-2019 02:28 AM
Further more :
https://slexui.cloudapps.cisco.com/SWIFT/LicensingUI/html/contact.html
M.
