Licensing in cisco prime
Debudas123
we have purchase cisco prime for a customer, we have got software paper license from distry.  3 license is there with defferent PAK
1. R-PI12-BASE-K9
2. L-PILMS42-50
3. L-PI12-LF-50-LIC
i have register first one and got the license file as per instruction given by cisco.
but when i want to register rest 2 items it will ask the for target device, so what will be the target device ?
thanks
Debu
15 Replies 15
AFROJ AHMAD
Hi Debu,
Rest 2 license are:
L-PILMS42-50                          Prime Infrastructure LMS 4.2 - 50 Device Base Lic
L-PI12-LF-50-LIC                        Prime Infrastructure 1.2 - Lifecycle - 50 Device Lic PAK
First one is for LMS (LAN Management Solution) and other is for PI 1.2
check the below link for more deatails:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729223.html#wp9000476
R-PI12-BASE-K9  >> this is the Base license which you have already installed,now you can install
L-PI12-LF-50-LIC to add more devices support in PI.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
i know, but when i want to regsiter rest 2 it will asking for target device, my question is what is the target device ?
thanks
debu
target is a Prime Infrastructure x.x version virtual device
virtual device means?
can u explane ?
we have already  1 5508 controller, 6 switches, 15 aps, so what will be the virtual device ?
thanks
debu
Hi Debu,
The Product ID and Serial number of the Prime Infrastructure product can be found by
logging into the User Interface and visiting the Administration > Licenses Page
and the summaryscreen will have the information you seek. If you have not deployed PI yet, then you have to do this first to get the information to fulfill the licensing.
Thanks-
Afroz
Okay,
then i have to install the LMS 4.2 first then i have to assign the product id and serial no of virtual device (LMS 4.2)
this is the procedure ?
Debu
Yes  , deployed PI \LMS  first
Thanks-
another thing is that we have not received any media(like CD/DVD), so how can i install? i have to download it ? if yes please send the link ..
thanks
debu
Here  are the links :
for LMS:
http://software.cisco.com/download/type.html?mdfid=284259296&flowid=37207&softwareid=280775102
for Prime Infrastructure:
http://software.cisco.com/download/release.html?mdfid=284422771&flowid=45323&softwareid=284272932&release=2.0.0&relind=AVAILABLE&rellifecycle=&reltype=all
Thanks-
Afroz
***** Ratings Encourages Contributors *****
okay, then i have to install both the software in same server...
thanks
debu
No , you can't installed these 2 softwares on same hardware.
okay then can i install LMS 4.2 in windows platform and PI 1.2 in a VM platform? how can it communice to each other ?
in registration part for PI 1.2 i have to assign VM platform serial no and product id, where it is asking for the same.
thanks
debu
yes you can do that...
why you want to communicate with each other.. ?
they are 2 different application . you should check the below link and undeestand what these products are :
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.2/quickstart/guide/cpi_qsg.html
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps11200/deployment_guide_c07-618226.html
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/getting_started/preface.html
Thanks-
Afroz
