03-28-2006 06:59 PM
Hi expert,
Please help on the LMS 2.5 can't login, it show that the cookies is disable but we have enable all the cookies in IE6. How to resolve this?
Thank you.
Rgds,
Au Yeong
03-28-2006 10:43 PM
Hi Au,
did you checked the following too:
In "Internet Options -> Privacy" you can set the cookie handling for single websites. If you or someone else have set the LMS IP address or Servername into the list with the status blocked you may set the cookies to what ever you want but they will not work!
Hope that works for you.
Best regards,
Frank
04-03-2006 02:08 AM
Hi Frank,
Thank for your feedback.
But I'd try what you said but nothing in the list.
Any other possibility?
TQ.
Rgds,
Au Yeong
04-03-2006 03:24 AM
This should be pretty easy I hope. I've experienced this before when you don't specify the proper url
https://{SERVERNAME OR IP}/CSCOnm/servlet/login/login.jsp verse using the proper (at least for LMS 2.5)
https://{SERVERNAME OR IP}:1741
If you use the first form you will always get cookies disabled on the splash screen. The second form will show cookies enabled.
04-03-2006 08:50 PM
I'd try but is show page cannot be display.
Any ideal?
04-05-2006 05:32 AM
Did you change the default port for the web server in your installation ? 1741 is default, but you have the option to pick another one.
