LMS 2.5 RME upgrade
srego4
Level 2
Level 2
I do not seem able to get my configs for any of my devices. I have been trying to look for the device credentials for RME (like in 2.2) but only find it in Common Services. Also I do nto find the credentials there for tacacs username & passwd. as I have these on some of my devices.
I have enabled archive management ... so what am I missing..
nhabib
Level 9
Level 9
RME 4.0 uses the credentials that are entered in the Device Credential Repository (part of Common Services)
The fields you need to fill out are Primary Username / Password
Thanks nhabib.
Which brings me to another question...
I have tacacs only on abt. 600 devices, and no tacacs for abt 1000 devices. How can I do these all at a time? Also for catOS switches the fields are different (from lms2.2) the enable secret was not used instead the enable was used.
appreciate the response.
