LMS 2.5
jllugar
I have upgraded to LMS 2.5 and wonder what happend to certain reports like offline device report and reachability dashboard?? Places where I could see quickly when things were 'down'.
nhabib
Level 11
Level 11
The availability portion of RME has been removed from LMS 2.5
9 Replies 9
nhabib
Level 11
Level 11
Any suggestions on what to use in its place?
thanks!
under device troubleshooting go to device center
that's basically it 😞
Ok, thanks. I finished my LMS install today and wanted to let you know that I used some of your other posts to help me. THANKS!
Another option is to set the device polling option low - like around 30 seconds, and then use the topology maps as "up/down" indicators. I have set this up using the RME "all devices" view and it works fairly well.
where are the topology maps???
thanks!
Campus Manager -> Topology Services
Campus Manager -> Topology services.
From there, open up one of the trees, such as the RME tree. Right click on the "All Devices" view and click on "Display View." That will load the toplogy map.
Thank you. I knew where topology were but I didn't know the right-click for the map part!
