lms 2.6 dbase move from C to D partition
afumar
I have an existing install of lms 2.6 on the C drive. Not sure if installing to other drive that C was even an option, hopefully it is, can someone please confirm?
option 1: backup, re-install to D drive then restore the backup
option 2: if possible, move the dbase from C to D partion.
I'm leaning towards option 2. If it is possible, can someone kindly provide the procedure or links to it?
Thank you,
Allan
Joe Clarke
Your only viable option is 1, and it is supported, and should work.
