07-16-2008 09:26 AM
I'm having a problem with LMS 2.6 and pushing configs out to our firewalls. We don't allow telnet into the firewalls, only SSH. LMS pulls the configs without a problem, but when I try to modify a config and push it out to a firewall it only seems to attempt to telnet and fails, so the config never gets pushed out. I made sure that SSH is the first in the list under RME transport settings for config deploy. Am I missing something else?
Solved! Go to Solution.
07-16-2008 02:52 PM
Ok I enabled debugging for the config job...but the information in the job browser looks the same...where would I find the debug logs?
07-16-2008 07:26 PM
/var/adm/CSCOpx/files/rme/jobs/ConfigEditor on Solaris and NMSROOT\files\rme\jobs\ConfigEditor on Windows.
