LMS 2.6 support Cisco ACE Application Control Engine Module
u346874_2
Any idea when LMS 2.6 starts support Cisco ACE Application Control Engine Module. Now looks like it that i cant fetc config from that module. Also DFM cant manage that module.
Juha
9 Replies 9
Joe Clarke
ACE support for LMS 3.6 and 3.0 was only added in the latest round of device updates (in June and July). You will need to download the 2.0.9 Service Pack to get ACE support for DFM.
My dfm version is 2.0.9 but still device discovery says UNKNOWN for ACE? I tryed to do rediscovery but same thing. Any idea what try next.
Juha
What is the sysObjectID of the device?
This is second row from snmpwalk. Is that what you mean.
.iso.3.6.1.2.1.1.2.0 = OID: .iso.3.6.1.4.1.9.1.730
juha
Support for the ACE as a standalone device is not present. It can only be managed through the switch.
Does that mean that it is not bossible to get backup from ACE's config itself. ACE boys starts again ask me is it possible. All context are needed to back up.
Juha
No, config and software management operations are not supported for this module in RME. It is only supported for inventory collection.
Is that config backup possible later versions of RME.
thanks
Juha
No, config management is not supported in any version of RME.
