09-28-2007 08:09 AM
What determines the length of time that syslog is retained by Ciscoworks? We have a requirement to keep logs for 1 year, but only seem to have 2 months. The server has over 60 GB of free space, so there must be a config setting somewhere?
Solved! Go to Solution.
09-28-2007 09:55 AM
Hi Dave,
What did you upgrade *from*? Did you do the 2.5 -->2.5.1-->2.6 upgrade? Also, when you did the upgrade, did you do a data migration in accordance with:
If not, then yes, definitely this would explain the lack of syslog messages from the time prior to the upgrade.
HTH,
-Joseph
-Joe
09-28-2007 08:52 AM
Hi.
Check
RME-->Administration-->Syslog-->Set Purge Policy
HTH,
-J
09-28-2007 09:31 AM
Joseph,
The purge was set correctly for 365 days. Any ideas on how to determine why we only have 2 months. We did upgrade to 2.6 a couple months ago, would that purge all syslog?
Dave
09-28-2007 09:55 AM
Hi Dave,
HTH,
-Joseph
-Joe
09-28-2007 01:44 PM
Joe,
Did not do a data migration, so I think that solves the mystery.
Thanks for your help.
Dave
09-28-2007 01:56 PM
...anytime. :-)
-J
