03-23-2009 05:40 AM
Excuse me if I am missing the point here but...we have installed LMS on two servers, server one runs the Portal, CS, CM, Assistant and IU; the second server runs RME, CV, IPM and DFM (as well as the default CS, Portal and Assistant). I have run through the workflow for server setup and set up the two servers to use our ACS server for TACACS. Now this is where I may ne missing the point - when I sign into server one, and click on a ling to an applet on server two it asks me to authenticate again....I thought that with a multi server setup, and TACACS then I would only need to authenticate once to access applets across both servers.
03-24-2009 03:35 PM
You configured the port 443 on the slave server in the SSO.
But you are not using HTTPS, so it should be the port 1741 (default).
But I think it is not a bad idea to change to HTTPS from HTTP ;-)
03-25-2009 03:33 AM
tried to change the 443 to 1741 - however when I hit apply it says that it is unable to connect to the server on that port.
I will say that none of these settings were input by me - I used the server setuo workflow and it did it all itself
03-25-2009 04:24 AM
Did you try to change from HTTP to HTTPS?
You can find it under
CS -> Server -> Security -> Browser-Server Security Mode Setup
Perhaps the workflow doesn't work for that part.
I think the port for the SSO and the port for web access should be the same.
03-25-2009 05:22 AM
Changed that (although I did have reservations as it is listed under the "single server setup" heading)....but I changed it on the second server anyway - and now cannot access the server at all - just get 403 forbidden...anyone know how to reset the browser security setting from the command line????
03-25-2009 05:33 AM
