LMS 3.0 adding devices
chrisayres
Is there anyway I can get LMS 3.0 to learn the name of devices from an SNMP get, so I don't have to bother with DNS or LMHosts.
8 Replies 8
David Stanford
You will still need DNS in LMS 3.0 for name resolution. There is no way to have it do an snmp get for hostname in the app.
How is it that a cheaper less functional network management application like solarwinds is capable of extracting this information while LMS still can not.
Don't know but I have solved my problem using solarwinds.
I am getting solarwinds IP Address Mgmt to scan the network and get the SysName by SNMP. This then produces a db that is readable by MS Access. So I schedule an FTP to copy the file to my DNS server every so often(that I have installed MS Access on). I have built a query in Access that produces a format that is useable by DNS. Next I have a macro that automatically exports this query to DNS. So I now have a DNS server that automatically updates itself to include the details of all my cisco devices.
Thats a lot of work for something so simple. Here's something I found last night using LMS 3.0 and QPM 4.0. LMS will not resolve the device name when adding devices. I used QPM to add a device and it pulled the complete hostname with domain suffix. RouterA.domain.com.
SO how is it possible that this CiscoWOrks app can do it but the core LMS product can't?
Cisco?
Hi daniel,
if you properly setup DNS and configure Campus Manager -> Admin -> Device Discovery -> Discovery Settings
and Check "Resolve by Name"
This inserts the discovered devices in DCR with its names.
Best regards,
Frank
Why should you have to bother doing this. When LMS discovers a device it does an SNMP get, so why can't it just get the name from SNMP like most other management tools do (even free ones)
Yes, this is the point. Why can't you just extract the simple info that other simple snmp applications can? Why do I need to set up a whole DNS infrastructure and maintain it? Why does CiscoWorks QPM accomplish this but LMS can't?
This has also been a point of contention as we try and synchronise our network management tools' inventories. Another product that Cisco's OEMing Opsware (now HP) NAS also grabs the device host name.
Why is this a useful bit of information for Ciscoworks ? Let me list it in one word: BUGS!
Since the DCR was introduced as the repository for all applications we've been fighting to keep it listing only a single instance per device.. sometimes its a loosing battle. Hostname is a pretty good flag to sort a list by (I know serial number is good too, but not all cisco devices can report that) to identify duplicates.
Maybe in a smaller shop with 50-100 devices this isn't a problem but when your on the scale of thousands of devices it really is. I'm at 5,600 devices and growing so I do feel this pain.
