The current issue I am facing is that no host (end user) IP addresses are displayed, only MAC addresses. I have a 6509 w/msfc2 as our only core switch. I tried using the SUP IP as the seed device and then the msfc IP, but both gave the same result. I selected jump router boundries for both. Also when I use MSFC as the seed device, it does not appear in the dicovered devices. However, the sup does.
The snmp string ro is set for both the SUP and MSFC, and verified via Credential Verification. I havent confirmed if CDP is running on the MSFC (another administrator's property), but I hope it isnt required.
Below is the versions and config that I am using.
- Common Services 3.1.0
- Campus Manager 5.0.0
- CiscoView 6.1.6
- RME 4.1.0
- IPM 4.0.0
- Assistant 1.0.0
- DFM 3.0.0
- LMS Portal 1.0.0
- IU 1.7.0
- Seed currently set as the SUP IP
- Discovery set to scan all vlans
- Jump Router boundries is enabled.
All Help is appreciated
