LMS 3.0 Solaris Hardware Requirements
We are in the planning stages of switching from a Windows platform to Solaris for LMS 3.0. What would be the optimal hardware specs for a 10,000 node system? If you have model numbers that would be great. Is it better to use a T1/2 processor or should we stick with the UltraSparc III/IV series? Is it possible for one server to handle RME and Campus together or should they be split? We would be using DFM on a separate server regardless. Thank you for all your help.
Joe Clarke
For this configuration, you'll need at least two quad processor UltraSPARC IV at 1.0 GHz (e.g. SunFire V490, V890, etc.) servers . Each server can have all applications installed.
As for other supported processors, you can use a US III server, or a US T1. But I would stick with a US IV, IV+, or T1.
