LMS 3.1 Installation Error
Mhon Baul
hi all,
I got problem installing my new lms 3.1 in solaris 10. When I tried to select the options wether its typical or custom install, I always get this error. Attach here is the error i get upon installation. Hope you can help me with my problem. Thanks in advanced!
mhon
Joe Clarke
Assuming the DVD is locally mounted, it looks like you either have a bad DVD, or bad drive. If you have copied the contents, or this is a network-mounted DVD, then you should try installing LMS from local media.
Joe Clarke
Joe Clarke
The DVD is locally mounted. Is it possible that i have a bad hard drive or dvd? How did you know that based from the logs? thanks!
You're missing critical files. On read-only media, if expected files are missing, that typically points to bad media, or a bad drive.
