Since upgrading from LMS 2.6, all the NetConfig jobs remain in perpetual "Running" status, despite having completed the config changes on the target devices. Each job's "Job Summary" shows "Status: Job Running", while "Device Details" shows "Update Pending". Each job has to be manually stopped, which transioned them into "Stop initiated" state. The exact same type of jobs exhibited no such behavior
Failure Policy: Ignore failure and continue
E-mail Notification: [blah@fqdn.com]
Execution Policy: Parallel
Fail on Mismatch of Config Versions: Disabled
Copy Running Config to Startup: Enabled
Sync Archive before Job Execution: Disabled
Job Password: Disabled
The jobs are just adding a bunch interface config commands. I wonder if this behavior might be because RME 4.2's NetConfig now expects explicit "exit" in the job itself from config mode.
