LMS 3.2.1 DFM issues
Hello, I am facing the following errors with DFM.
When i try to create a notification group i get the following error:
There are no devices in the system (in Known state).
This may be because devices have not been added to DFM, because DFM is in the process of learning about added devices, or because all devices were selected for deletion. Check the Discovery Status page for more information.
This is my discovery summary.
StatusNumber of Devices
Known24
Learning0
Questioned0
Pending0
Unknown0
Also find attached all of the DFM logs.
TIA, Nicos Nicolaides
AFROJ AHMAD
Looking into the logs ,it look like you need to Re-intilaze the DFM database.
You can refer the link given by Joseph Clark for Reinitializing DFM:
https://supportforums.cisco.com/docs/DOC-8796
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroj,
I have re-initialized the DFM database with no success. I have enered the following commands:
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
I have also renamed
DFM.rps and DFM1.rps files under NMSROOT/objects/smarts/local/repos/icf.
(I have made them DFM.rps.old and DFM1.rps.old).
I will attach you the logs again.
