LMS 3.2.1 ICServer push CPU to 100%
mladenp
Recently I have problem with Inv. collection jobs because some time after job start CPU goes to 100% and stay like that. I can only do "pdterm ICServer" and than CPU goes to normal. I have done some troubleshoot and discovers that ICServer like to stuck on particular devices (switches), while on other devices (routers) whole job is complete without any problems. I have attached IC_Server.log with example of one unsuccessful job done on 3750 switch. Job is stuck 2 min after start. Any help would be appreciated.
Best regards,
Mladen
8 Replies 8
AFROJ AHMAD
Hi Maiden,
Run this command >> pdterm EnergyWise
wait for few minutes and check the CPU .
If it goes normal ,let me know.
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hello Afroj,
There isn't EnergyWise process:
C:\Users\cwsadmin>pdshow -brief
  Process               State                                     Pid
  Tomcat                Program started - No mgt msgs received    10524
  TomcatMonitor         Running normally                          12928
  Apache                Program started - No mgt msgs received    11080
  RMEDbEngine           Program started - No mgt msgs received    11172
  Proxy                 Program started - No mgt msgs received    13168
  ProcSysBus            Program started - No mgt msgs received    17264
  OpsxmlDbEngine        Program started - No mgt msgs received    10144
  OpsXMLRuntime         Program started - No mgt msgs received    4648
  CWAPublisher          Administrator has shut down this server   0
  NameServer            Program started - No mgt msgs received    9824
  NameServiceMonitor    Running normally                          4588
  EDS                   Running normally                          11256
  LicenseServer         Program started - No mgt msgs received    6784
  INVDbEngine           Program started - No mgt msgs received    13316
  FHPurgeTask           Transient terminated                      0
  FHDbEngine            Program started - No mgt msgs received    4172
  ESS                   Program started - No mgt msgs received    10896
  EssMonitor            Running normally                          12388
  EventFramework        Program started - No mgt msgs received    15756
  PMServer              Running normally                          14984
  SyslogCollector       Program started - No mgt msgs received    15716
  EPMDbEngine           Program started - No mgt msgs received    1368
  EPMServer             Running normally                          3616
  FHServer              Running normally                          10740
  diskWatcher           Running normally                          15052
  DFMMultiProcLogger    Program started - No mgt msgs received    17048
  DFMLogServer          Program started - No mgt msgs received    13124
  DFMCTMStartup         Administrator has shut down this server   0
  DfmBroker             Program started - No mgt msgs received    4152
  DfmServer             Running normally                          15852
  DfmServer1            Running normally                          4900
  DCRDevicePoll         Transient terminated                      0
  CSSCPServer           Program started - No mgt msgs received    5148
  CSRegistryServer      Running normally                          7616
  CSDiscovery           Never started                             0
  CmfDbEngine           Program started - No mgt msgs received    9904
  CmfDbMonitor          Running normally                          11720
  DCRServer             Running normally                          8484
  CMFOGSServer          Program started - No mgt msgs received    14232
  CampusOGSServer       Program started - No mgt msgs received    8820
  EssentialsDM          Running normally                          7872
  ConfigMgmtServer      Program started - No mgt msgs received    14548
  ICServer              Running normally                          6396
  RMEOGSServer          Program started - No mgt msgs received    16004
  PMCOGSServer          Program started - No mgt msgs received    12992
  TISServer             Program started - No mgt msgs received    8616
  DFMOGSServer          Program started - No mgt msgs received    9024
  InventoryCollector    Running normally                          16668
  Interactor            Program started - No mgt msgs received    9368
  InventoryCollector1   Program started - No mgt msgs received    7516
  Interactor1           Program started - No mgt msgs received    9708
  NOSServer             Running normally                          11108
  PTMServer             Running normally                          13172
  EDS-GCF               Running normally                          11856
  jrm                   Running normally                          12620
  2820                  Never started                             0
  2821                  Never started                             0
  3295                  Never started                             0
  CTMJrmServer          Running normally                          3848
  ChangeAudit           Program started - No mgt msgs received    11224
  SyslogAnalyzer        Program started - No mgt msgs received    7456
  DataPurge             Administrator has shut down this server   0
  ANIDbEngine           Program started - No mgt msgs received    6340
  ANIServer             Running with busy flag set                14464
  UTMajorAcquisition    Transient terminated                      0
  MACUHIC               Running normally                          3968
  UTLITE                Running normally                          8088
  UTManager             Running normally                          4432
  VNMServer             Program started - No mgt msgs received    16680
  WlseUHIC              Running normally                          4712
  AdapterServer1        Program started - No mgt msgs received    6652
  AdapterServer         Program started - No mgt msgs received    3344
Mladen
Hi Mladen,
what is the Size of RME database.
Can you send the screenshot of /NMSROOt/CSCOPx/database/rmeng
Also have you seen any pattern or any specific device like 3750 which is causing issue while inventory polling.
as there are Bugs related to this.
Hello Afroj,
If I made right conclusion ICServer have problems with switches where some changes in inventory are detected, inventory polling jobs never stuck, only inventory collection...
2960 and 3750 cause problems.
Mladen
Hi Mladen,
Enable the debugging for the Inventory Collection process as follows:
    Please look for the IC_Server.log (NMSROOT\log\), clean the contents of
the files,
    and save them and after that enable debugging:
    a. RME -> Admin -> System Preferences -> Loglevel Settings, specify the
following:
    -- Application = ICServer
    -- Inventory Collection Service = DEBUG
    -- Inventory User Interface = DEBUG
    -- Inventory Collection Jobs = DEBUG
    -- Click Apply
   b. Redo the Inventory Collection for 1 of the (3750 and 2960) device : RME ->
Devices -> Inventory -> Inventory Jobs.
   c.  Once the job is finished, send me the following:
   -- $NMSROOT\log\IC_Server.log
Thanks-
Hello Afroj,
Job is started at 1:05pm, cpu goes to 100% around 1:07pm/1:08pm. Pdterm ICServer is executed at 1:15pm.
Hi ,
Configure the below SNMP VIEW on one of the 3750 and then run the inventroy and check the CPU.
snmp-server view cutdown iso included snmp-server view cutdown ciscoFlashMIB excluded snmp-server community view cutdown RO
Thanks-
Afroz
Hello Afroj,
Done, but without improvement.
Mladen
