09-03-2013 12:59 AM
Recently I have problem with Inv. collection jobs because some time after job start CPU goes to 100% and stay like that. I can only do "pdterm ICServer" and than CPU goes to normal. I have done some troubleshoot and discovers that ICServer like to stuck on particular devices (switches), while on other devices (routers) whole job is complete without any problems. I have attached IC_Server.log with example of one unsuccessful job done on 3750 switch. Job is stuck 2 min after start. Any help would be appreciated.
Best regards,
Mladen
09-04-2013 06:55 PM
Hi Maiden,
Run this command >> pdterm EnergyWise
wait for few minutes and check the CPU .
If it goes normal ,let me know.
09-05-2013 12:02 AM
Hello Afroj,
There isn't EnergyWise process:
C:\Users\cwsadmin>pdshow -brief
Process State Pid
Tomcat Program started - No mgt msgs received 10524
TomcatMonitor Running normally 12928
Apache Program started - No mgt msgs received 11080
RMEDbEngine Program started - No mgt msgs received 11172
Proxy Program started - No mgt msgs received 13168
ProcSysBus Program started - No mgt msgs received 17264
OpsxmlDbEngine Program started - No mgt msgs received 10144
OpsXMLRuntime Program started - No mgt msgs received 4648
CWAPublisher Administrator has shut down this server 0
NameServer Program started - No mgt msgs received 9824
NameServiceMonitor Running normally 4588
EDS Running normally 11256
LicenseServer Program started - No mgt msgs received 6784
INVDbEngine Program started - No mgt msgs received 13316
FHPurgeTask Transient terminated 0
FHDbEngine Program started - No mgt msgs received 4172
ESS Program started - No mgt msgs received 10896
EssMonitor Running normally 12388
EventFramework Program started - No mgt msgs received 15756
PMServer Running normally 14984
SyslogCollector Program started - No mgt msgs received 15716
EPMDbEngine Program started - No mgt msgs received 1368
EPMServer Running normally 3616
FHServer Running normally 10740
diskWatcher Running normally 15052
DFMMultiProcLogger Program started - No mgt msgs received 17048
DFMLogServer Program started - No mgt msgs received 13124
DFMCTMStartup Administrator has shut down this server 0
DfmBroker Program started - No mgt msgs received 4152
DfmServer Running normally 15852
DfmServer1 Running normally 4900
DCRDevicePoll Transient terminated 0
CSSCPServer Program started - No mgt msgs received 5148
CSRegistryServer Running normally 7616
CSDiscovery Never started 0
CmfDbEngine Program started - No mgt msgs received 9904
CmfDbMonitor Running normally 11720
DCRServer Running normally 8484
CMFOGSServer Program started - No mgt msgs received 14232
CampusOGSServer Program started - No mgt msgs received 8820
EssentialsDM Running normally 7872
ConfigMgmtServer Program started - No mgt msgs received 14548
ICServer Running normally 6396
RMEOGSServer Program started - No mgt msgs received 16004
PMCOGSServer Program started - No mgt msgs received 12992
TISServer Program started - No mgt msgs received 8616
DFMOGSServer Program started - No mgt msgs received 9024
InventoryCollector Running normally 16668
Interactor Program started - No mgt msgs received 9368
InventoryCollector1 Program started - No mgt msgs received 7516
Interactor1 Program started - No mgt msgs received 9708
NOSServer Running normally 11108
PTMServer Running normally 13172
EDS-GCF Running normally 11856
jrm Running normally 12620
2820 Never started 0
2821 Never started 0
3295 Never started 0
CTMJrmServer Running normally 3848
ChangeAudit Program started - No mgt msgs received 11224
SyslogAnalyzer Program started - No mgt msgs received 7456
DataPurge Administrator has shut down this server 0
ANIDbEngine Program started - No mgt msgs received 6340
ANIServer Running with busy flag set 14464
UTMajorAcquisition Transient terminated 0
MACUHIC Running normally 3968
UTLITE Running normally 8088
UTManager Running normally 4432
VNMServer Program started - No mgt msgs received 16680
WlseUHIC Running normally 4712
AdapterServer1 Program started - No mgt msgs received 6652
AdapterServer Program started - No mgt msgs received 3344
Mladen
09-05-2013 12:21 AM
Hi Mladen,
what is the Size of RME database.
Can you send the screenshot of /NMSROOt/CSCOPx/database/rmeng
Also have you seen any pattern or any specific device like 3750 which is causing issue while inventory polling.
as there are Bugs related to this.
09-05-2013 12:31 AM
Hello Afroj,
If I made right conclusion ICServer have problems with switches where some changes in inventory are detected, inventory polling jobs never stuck, only inventory collection...
2960 and 3750 cause problems.
Mladen
09-05-2013 10:33 PM
Hi Mladen,
Enable the debugging for the Inventory Collection process as follows: Please look for the IC_Server.log (NMSROOT\log\), clean the contents of the files, and save them and after that enable debugging: a. RME -> Admin -> System Preferences -> Loglevel Settings, specify the following: -- Application = ICServer -- Inventory Collection Service = DEBUG -- Inventory User Interface = DEBUG -- Inventory Collection Jobs = DEBUG -- Click Apply b. Redo the Inventory Collection for 1 of the (3750 and 2960) device : RME -> Devices -> Inventory -> Inventory Jobs. c. Once the job is finished, send me the following: -- $NMSROOT\log\IC_Server.log
Thanks-
09-06-2013 05:40 AM
09-06-2013 09:30 PM
Hi ,
Configure the below SNMP VIEW on one of the 3750 and then run the inventroy and check the CPU.
snmp-server view cutdown iso included snmp-server view cutdown ciscoFlashMIB excluded snmp-server communityview cutdown RO
Thanks-
Afroz
09-10-2013 12:47 AM
