LMS 3.2.1 will not load correctly
benchj
have been trying to load LMS3.2.1 on a 2008 VM ware box.  Initially had problems with services having to be manually changed or forced.  Once that was overcome it logs in but Apache feeds a never-ending 302 redirects until either the browser of the web server aborts.  Any suggestions
Joel Monge
Check on steps 1 through 3 from this DOC.  If those things are in place and problem continues, post the startup services setup in Windows along with latest "pdshow" output.  Was this originally working fine?
