LMS 3.2 and Cisco Small Business Switches
Mario Elia
Hi there,
I'm currently using LMS 3.2 to monitor my network. We've recently purchsed a few of the Cisco Small Business Switches, the SF 300-24 model to be exact. They're considered 'managed switches' (tho thier CLI is terrible) and I would like to monitor them in CWLMS. My problem is that once I add it to CS, it doesn't resolve to anything, just sits there as a blue box with a question mark. I'm assuming this means that these devices are not (currently) supported by LMS 3.2 - do you know if that will change, or how I can go about managing this device with LMS 3.2?
Marvin Rhoads
Unfortunately that series of products is not supported in any version of LMS (or even Cisco Network Assistant - CNA).
Cisco provides the FindIt utility to manage them:
http://www.cisco.com/en/US/products/ps10660/tsd_products_support_series_home.html
Hope this helps.
Marvin Rhoads
Hope this helps.
Thanks Marvin.
Do you know if these devices support SNMP traps? And does the FindIT deal with them? I'm trying to monitor these as I would a regular switch on LMS 3.2 for example. I know it's a much toned down version of the IOS/CLI, but I'd still like to get an alert if/when a device is disconnected from the SF300.
