11-05-2009 04:08 AM
Hi Forum,
my customer play to deploy LMS 3.2 and last QPM 4.1.2 on the same server.
In the documentation of QPM only Common Services 3.2 are mentioned. Does this match with LMS 3.2 - since LMS utilizes CS 3.3?
Does anybody know something about that?
Thanks a lot in advance.
Frank
Solved! Go to Solution.
11-05-2009 06:26 AM
No, you cannot install these two on the same server. Doing so will break both products. You must dedicate a server to each since they require different versions of Common Services.
11-05-2009 06:26 AM
02-10-2011 09:15 AM
If we were to dedicate a vm to it as oppposed to a physical server do could you see any issues?
02-10-2011 09:56 AM
A VM per suite is fine. I was using "server" in the loose sense. Today, a server can be a VM.
