08-30-2011 12:09 AM
If i reinialize(restore) the cmf database.do i need to reinialize all the databases.???
or if i reinialize the cmf database and do bulk import the devices is enough??
Thanks..
Channa
Solved! Go to Solution.
08-30-2011 12:43 AM
Hi Channa,
Reinitializing a database will destroy All data associated with that database. If you need to reinitialize the cmf database, you will lose All data in ALL LMS applications.
If you reinialize CMF and then do a bulk import of all your devices ..It means you are starting from scratch or I would say it would be just like a fresh Installation..
I hope this answer your query..
Afroj
08-30-2011 12:43 AM
Hi Channa,
Afroj
08-30-2011 02:08 AM
Thanks for update Afroj...
Is there any way to export all the pollers from HUM module.so post bulk import i can import the pollers back.
Channa
08-30-2011 02:26 AM
Hi Channa,
As per my understanding there is no way to Export and Import the Pollers in HUM.
Afroj
