Showing results forĀ
Search instead forĀ
Did you mean:Ā
LMS 3.2 need to restore cmf database.
If i reinialize(restore) the cmf database.do i need to reinialize all the databases.???
or if i reinialize the cmf database and do bulk import the devices is enough??
Thanks..
Channa
AFROJ AHMAD
Hi Channa,
Reinitializing a database will destroy  All data associated with that database.  If you need to reinitialize the cmf database, you will lose  All data in  ALL  LMS applications.
If you reinialize CMF and then do a bulk import of all your devices ..It means you are starting from scratch or I would say it would be just like a fresh Installation..
I hope this answer your query..
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Channa,
Afroj
Thanks for update Afroj...
Is there any way to export all the pollers from HUM module.so post bulk import  i can import the pollers back.
Channa
Hi Channa,
As per my understanding there is no way to Export and Import the Pollers in HUM.
Afroj
