LMS 3.2 not recognizing C3560CG
pawelkostera
We have recently bough a couple of the new C3560CG-8PC-S switches, but they are not being recognized by the LMS 3.2;
Is there any patch or device firmware I can update on the LMS to have support of that switch on the LMS 3.2 ?
Pawel Kostera
Thomas Masters
To determine device support in LMS 3.2:
Use device center and snmpwalk the device using OID .1.3.6.1.2.1.1.2
Then see if it is in the supported device table:
http://www.cisco.com/en/US/partner/products/sw/cscowork/ps2425/products_device_support_tables_list.html
If there is a patch you will find it on the download page
http://www.cisco.com/cisco/software/type.html?mdfid=282635181&flowid=16561
Answer:
Scope : LMS 3.2.1/Windows
Symptoms : Want to know the support for WS-C3560CG-8PC-S with LMS 3.2.1
Resolution : It is not supported with LMS 3.2.1 and would be supported
begins in LMS 4.1.
Thomas Masters
Answer:
begins in LMS 4.1.
